I have the car listed above BASE engine. The car had overheat problem. Temperature gauge indicated normal condition (middle between H and C) for a while. Then, it certainly raised to H (hot) in manner of minutes. Water was seen boiling from radiator water container. I noticed that the cooling fan did not run at that time. Issue is not seen during freeway driving.
I replaced thermostat and coolant temperature sensor but issue was still there.
Fuse for fan was good. I have located thermo fan switch. If I left ignition switch on (engine is off), and removed the connector from the thermo fan switch, the fan worked. The thermo fan switch is shown in the first picture.
I was about to replace this unit. But I ran into another article about different "fan sensor" located in the left side of the engine, below the exhaust manifold as in second picture (viewed and captured from YouTube video). I am not sure if second picture is applicable to my engine. It is not easy to reach.
Could you give me advice on what steps I should take to narrow down the problem in order to replace the right component?
Thanks,
-Tim
Thanks,
-Tim
Feb 24, 2018 at 7:26 PM
