Engine Oil Pump Upper Drive Shaft
1986 FORD MUSTANG
80,000 MILES • 2.3L • 4 CYL • TURBO • RWD • MANUAL
JAALESSI52
I need an Engine Oil Pump Upper Drive Shaft for a 1986 SVO Mustang but the part is unavailable. Do you know if the same part from a 1990 Ford Ranger will fit?
Aug 25, 2015 at 10:17 AM
HMAC300
  • 48,601 POSTS
I just looked online at rock auto and they have it listed.for like $11 the one out of a ranger may fit or be a different size it's a hex shaft. you don't want it to be to short or to long. if the shaft broke look for valve stem seals in oil pump and then put a screen like a house screen between pump and block so it doesn't happen in the future. make sure screen is steel not plastic.
Aug 25, 2015 at 12:13 PM
