Where is the Engine Oil Pressure Sensor Located?
2021 CHEVROLET EQUINOX
45,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
BREANNA12
Oil Pressure Sensor location needed on the vehicle listed above?
Thanks
Dec 14, 2022 at 11:57 PM
The oil pressure sender is located right above the starter motor. Here is a diagram in the images below. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Dec 15, 2022 at 2:56 PM
