Engine oil entering coolant system
1999 HONDA ACCORD
286,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
JEFF BARRETT
Runs great. No moisture in crankcase. Good compression across all four cylinders. With the research that I found on this f23 VTEC engine. I found that Honda had a problem from 1999 to 2002 concerning porous engine block castings.
Jul 16, 2019 at 1:36 AM
Good morning,
This indicates a either a cracked clock or the block being porous as you stated.
https://www.2carpros.com/articles/how-a-car-engine-works
The engine will have to be replaced.
Jul 16, 2019 at 2:54 AM
JEFF BARRETT
Thanks Roy, appreciate your time and effort.
Jul 17, 2019 at 2:46 PM
You are welcome.
Always glad to help.
Jul 17, 2019 at 2:52 PM
