15w40 is mostly for diesel engines not gas. if they have synthetic get that in 0w30 as that is what is recommended or 5w30 if not available. air filter if used in dirt/gravel areas should be replaced every 6 months if not once a year. your car is listed at 4.2L for a oil fill Toyota genuine motor oil is also recommended or equivalent. Here is a guide to help walk you through the oil change with the oil type and capacity below.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Oil Grade Oil Viscosity (SAE)
ILSAC multigrade engine oil 0W-20
Standard Oil Grade (for Mexico)
API grade SL "Energy-Conserving", SM "Energy-Conserving", SN "Resource-Conserving" or ILSAC multigrade engine oil
0W-20
5W-20
5W-30
10W-30
API grade SL, SM or SN multigrade engine oil
15W-40
20W-50
Standard Capacity
Item Standard Condition
Drain and refill (with oil filter change) 4.2 liters (4.4 US qts, 3.7 Imp. qts)
Drain and refill (without oil filter change) 3.9 liters (4.1 US qts, 3.4 Imp. qts)
Dry fill 4.7 liters (5.0 US qts, 4.1 Imp. qts)
Mar 28, 2017 at 12:25 PM
