Engine not revving?
2011 MERCEDES BENZ E350
244,577 MILES • V6 • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
The vehicle's engine is working very fine but sometimes it goes into limp mode, at this point the engine will not rev even though the gas pedal is pressed. The battery voltage is 14.02V whenever the engine is working.
Below are the scanned results.
What could be the cause?
Nov 10, 2023 at 8:29 AM
The code # 630900 tells us the engine control module is no good, here is the location and how to change it out. You can get a preprogrammed unit by searching Google or Ebay. Once the unit is replaced clear all codes in the CAN before you try starting the engine. Check out the images below. Let us know how it goes.
Nov 10, 2023 at 10:43 AM
BLESSING EWOBOR
  • 754 POSTS
The code is stored not current, could it still has effect. Thank you sir.
Nov 10, 2023 at 7:11 PM
Can you clear the codes and try to start the engine to see if it comes back? You may need to try and drive it, also I have seen a dirty through bore cause this problem as well if the code doesn't come back.
Here are two guides to help us fix it:
and
https://www.2carpros.com/articles/reduced-power-limp-mode
Nov 11, 2023 at 10:03 AM
BLESSING EWOBOR
  • 754 POSTS
Thank you sir.
Nov 11, 2023 at 10:48 AM
You are welcome.
Nov 13, 2023 at 8:42 AM
BLESSING EWOBOR
  • 754 POSTS
Good evening,
Please could you help me with wire diagram showing the grounds with the locations?
Thank you
Nov 13, 2023 at 8:48 AM
Engine grounds? Engine wiring diagrams? If so, here are the engine wiring diagrams and a guide to help with the testing which shows the ground locations:
Nov 13, 2023 at 10:14 AM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much.
Nov 13, 2023 at 11:53 AM
You are welcome, we are here to help.
Nov 14, 2023 at 7:25 AM
