Engine not firing [after assembling it]
2008 FORD EVEREST
125 MILES • 3.0L • 4 CYL • 4WD • MANUAL
HOPMAS
  • 4 POSTS
The vehicle developed a problem when a bolt that holds one of the injector nozzle broke leading to excessive fuel leakage from the affected nozzle.
For purpose of re-machining the bolt, the cylinder head was removed. After removing it was further discovered that only two cylinders showed signs of combustion. However, this was not given attention. Only the bolt problem was sorted out and the engine was assembled back.
Unfortunately, vehicle cant start. The engine is cannot turn. A diagnostic tool was used and it indicated there is no problem. The timing was checked and seems okay.
The mechanic concluded that it is because of the two nozzles that he suspected to be blocked. The nozzles were taken for testing and it was confirmed that two of them are blocked due to carbon accumulation.
Now my question is it correct that the reason the engine cannot fire is because full compression in the the cylinders cannot be attained with only two injector nozzles? That all four nozzles need to be working for it to start? After all, before all the problems, the engine was still running even with two injector nozzles blocked. What do you think?
Mar 23, 2017 at 11:42 AM
STEVE W.
  • 15,113 POSTS
Which engine do you actually have? For the Everest/Endeavor I see a 2.2l and 2.5l 4 cyls. and the 3.2 5 cyl. All diesels. I'm surprised that it ran at all on 2 cylinders. Must have been an interesting sound. I suspect that they just recently became plugged.
I would clean all the injectors. That ensures that they all get the same fuel flow.
Then you say it doesn't turn over. Check all of the connections. Would only take one ground wire or the wire to the starter solenoid to prevent it from doing anything.
Mar 23, 2017 at 12:59 PM
HOPMAS
  • 4 POSTS
Its a 2.5l.
Mar 31, 2017 at 10:23 AM
Here is a guide on how to test the injectors also one on why the engine will not start. Check the basics and then get back to us so we can keep helping you.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
and
Best, Ken
Apr 3, 2017 at 11:58 AM
