For years we were changing the oil and filter with synthetic oil at the Walmart superheated every three months and the engine ran just fine, then last August 13th we changed the oil at Tire Kingdom with full synthetic oil and found out that unlike Walmart Tire Kingdom recommends oil changes at 8,000 miles and now it has been four months since the last oil change and the engine has started making noise probably the timing chain. Also, when it is idling in drive with the air conditioning on the tachometer jumps between 500 RPMs and 1,000 RPMs making an uneven idle. Did the delayed oil change hurt the engine and what causes the uneven idle?
Dec 13, 2022 at 2:00 PM
