Aunt owned and maintained it well. sat for almost a year. It started right up as if it was on a battery tender. Everything works well except air cond. 80,000 miles. Changed oil and drove it from PA to FL. The engine has a noise that does not sound right. Did not want to spend money to have air fixed if engine was not good. Took it to shop and noise coming from tension pulley. They changed it and still had the noise. I believe the timing gears are right behind this tension pulley. Could those gears be bad at 80,000?
Jul 22, 2022 at 11:36 AM
