code p052B, engine noise?
2015 BMW 428I XDRIVE
100,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I bought this one with engine noise that I am almost 100% it's not coming from the bottom end, would start for a second and stall. marble sound noise, one code p052B related to camshaft.
it is not an XI, regular 2wd.
Feb 10, 2024 at 1:21 PM
More specifically, the code indicates camshaft A is retarded at start up. Most commonly, this is going to be an issue with either a VVT actuator or VVT timing solenoid. However, it could be a timing issue as well.
Keep in mind, the VVT is controlled by engine oil. If you are hearing a lot of noise, I suspect the solenoid was starved of oil due to dirt or extremely low oil.
I attached a pic below showing the actuators. Start by removing and inspecting them. Also, inspect the timing chain for wear.
See pic below.
Feb 10, 2024 at 5:53 PM
BHAMDOC1973
  • 2,008 POSTS
So, the front ones are the actuators, where are the solenoids?
Feb 10, 2024 at 6:59 PM
The solenoids are behind those. That is an actuator, the solenoid is at the cam.
Feb 11, 2024 at 2:40 PM
BHAMDOC1973
  • 2,008 POSTS
Oh, okay.
Feb 11, 2024 at 2:46 PM
BHAMDOC1973
  • 2,008 POSTS
Is this an interference motor?
Feb 11, 2024 at 6:48 PM
To the best of my knowledge, it is. Are you worried about it jumping time? If so, pull the spark plugs, take a borescope, and check in each cylinder for evidence of damage.
Let me know if I can help in any way.
Feb 11, 2024 at 8:35 PM
BHAMDOC1973
  • 2,008 POSTS
I removed the actuator, visually looks good. But when i put it back and left it unplugged the car started better and stayed on longer. I was able to get a better video of the noise.
Feb 13, 2024 at 8:34 AM
I listened to the video. Have you checked the timing? It sounded off when cranking.
Feb 13, 2024 at 2:47 PM
BHAMDOC1973
  • 2,008 POSTS
I only have code p52 have not checked the timing. even if it was off shouldn't make this noise.
Feb 13, 2024 at 2:50 PM
That's my fear. Could we be hearing internal interference?
Feb 13, 2024 at 3:08 PM
