Getting a violent banging noise from the engine. Decreases when in gear and stopped. Increases when accelerating.
Oct 14, 2024 at 7:46 AM
CERTIFIED EXPERT
It sounds like you have a rod bearing that has spun, but if you upload a short video of the engine running, I can tell for sure what's going on. These guides may help as well:
Please upload videos in your response of any problems so we can see what to help you with. Please check the engine oil level/condition as well.
Oct 14, 2024 at 11:23 AM
DAVID GREENHOUSE
MEMBER
The oil is good.About 50% life left. Level is good as well.
Video (Click to enlarge)
Oct 14, 2024 at 4:05 PM
CERTIFIED EXPERT
That does not sound good. can I ask you to confirm the engine size? Also, please remove the serpentine belt and start the engine to see if the noise goes away, this will confirm the engine is having an issue internally. Do not drive the car with the belt off or let the engine run for more than 1 minute. Thanks for the video, it helps.
