Engine noise?
2008 CHEVROLET AVEO
179,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RPJ
  • 97 POSTS
Thanks for the previous help with the engine vibration, the motor mounts were changed and now it is smooth as ever.
Now I'm hearing noise from the engine. Not sure why, but it's annoying. The vehicle has power, nothing is leaking, and after some driving time the noise does subside somewhat.
Any idea what this is? I will attach a video so the noise can be heard.
Thanks,
Roosevelt.
Mar 16, 2025 at 7:56 PM
RPJ
  • 97 POSTS
Here is the video.
Mar 16, 2025 at 7:58 PM
BORIS K
  • 836 POSTS
Thank you for the video, unfortunately you do not zoom into the area where the noise is coming from.
To try and find the noise see if the noise changes or goes away completely by removing the ancillary's belt.
You can then spin the ancillaries by hand to see which one is making noise.
how to remove belt:
https://youtu.be/U7D4pQjXvGs?si=0I6sJ5f3Njq_OSJi
Regards
Mar 17, 2025 at 10:36 AM
RPJ
  • 97 POSTS
Thanks,
The noise is from the Valve cover, but I will check and let you know.
Roosevelt
Mar 17, 2025 at 11:03 AM
RPJ
  • 97 POSTS
Also, the serpentine belt pulley was changed recently, if that helps.
Thanks
Mar 17, 2025 at 11:06 AM
BORIS K
  • 836 POSTS
If the noise sounds like scraping comes from the valve cover area, then it could be caused by a camshaft pulley scraping against the backing plate, a faulty coolant pump or a timing belt idler roller.
The below link shows the setup and possible source of noise:
https://youtu.be/MskBSyBWfFc?si=jF7IgDtucsZgXjdp
and
https://youtu.be/IUEsh6AhI8s?si=szFp6WkOeYwECKPp
A good video on how to try find noise:
https://youtu.be/3sgLRyzLtdU?si=QE4XYNxEbrE_V7L-
Cheers, Boris
Mar 18, 2025 at 3:10 AM
RPJ
  • 97 POSTS
Hello Boris,
It turns out the noise was from the alternator, the bearings failed. Thank God it wasn't from the engine block!
The repair shop, who replaced the original unit back in '23, replaced the unit at no cost save the labor (and that was discounted also!). The supplier, even though the unit was out of warranty, replaced it free of charge.
I could not be happier! Thanks for your help.
Roosevelt
Mar 19, 2025 at 3:16 PM
BORIS K
  • 836 POSTS
I am glad we could be of help; happy you got the noise sorted.
Cheers, Boris
Mar 20, 2025 at 2:03 AM
