Have you replaced the battery? When trying to start it, does it sound normal and turning fast enough to start? If it is, then we have to check if it is getting fuel and spark to the engine. Here are a couple links explaining how that is done:
The easiest thing to do is see if it starts for a couple seconds with starting fluid. If it does, then we know it is a fuel related issue. If it doesn't, then suspect it is an ignition spark related issue.
Let me know. Also, try the starting fluid trick and let me know the results.
Jan 19, 2020 at 1:15 PM
