I have replaced the engine mounts and made sure they are in the correct position, torqued the bolts with a breaker bar with and without lock washers and put new nuts on. The nuts are the correct thread, I took the old one to match it up. Made sure the transmission cross member was tight. Put lock washers on and made sure the transmission mount bolts are tight as well. After a few days of driving, the driver side motor mount starts making a popping sound and then I have to tap the accelerator to knock the rpm back down. Am I missing something? I can't figure this out.
I don't know if this is relevant to my problem or not. When I put the motor mounts in, I bolted the side with the pin first. Then I lowered the engine, checking the alignment as it came down and I realized the the engine was too the left of the motor mount bolts. I tried to align them back up but couldn't. In order to lower the engine on to the mounts, I had to barely put the nuts on the pin side of the mounts and then angle the mounts as I lowered the engine.
Aug 28, 2019 at 6:01 AM
