Hey, I want to change engine mount for my car. (Front two mount )
If possible valve cover gasket.
Nov 20, 2017 at 5:12 PM
KHLOW2008
CERTIFIED EXPERT
Such jobs are straight forward and simple thumb of rule is :
Anything that is restricting access to the mount or valve cover has to be removed.
A floor jack is required to lift the engine when mount is being removed. Be careful how high you lift the engine as there are hoses, pies and wireharness connected and could be damaged if too much force is applied to them when lifting the engine..
Nov 20, 2017 at 11:24 PM
ARUN333
MEMBER
I want to change the engine mount, can you help us?
Nov 21, 2017 at 6:38 AM
KHLOW2008
CERTIFIED EXPERT
Costing varies according to regions and best way to go about is to check with more than one garage to understand local prices.
Nov 22, 2017 at 7:05 AM
CERTIFIED EXPERT
Yes a jack is used under the engine.
Here are some diagrams (below) and a couple of guides to help you see what you are in for when doing the job:
