Engine Mount
2008 HONDA FIT
57,000 MILES • MANUAL
MIKE410
  • 4 POSTS
An auto shop told me the rubber part on the drivers side engine mount is worn. Is it absolutely necessary to replace this? What will happen if left with worn rubber, other than vibration noise, which isn't too bad as I haven't noticed it much.
Thanks!
Jan 19, 2016 at 12:26 PM
HMAC300
  • 48,601 POSTS
if you don't replace it you could put your foot on the gas and it can break other motor mounts.
Jan 19, 2016 at 3:31 PM
MIKE410
  • 4 POSTS
Thanks for the reply HMAC. What does the rubber part actually do? Excuse my ignorance.
Jan 19, 2016 at 4:03 PM
HMAC300
  • 48,601 POSTS
it stops the vibration between the engine and body
Jan 19, 2016 at 4:18 PM
MIKE410
  • 4 POSTS
So if I'm not noticing much vibration now, would it not be ok until I noticed vibration - to replace it?
Jan 19, 2016 at 4:44 PM
HMAC300
  • 48,601 POSTS
re read my first reply
Jan 20, 2016 at 6:51 AM
MIKE410
  • 4 POSTS
Ok thanks HMAC!
Jan 20, 2016 at 5:12 PM
