Hello again,
There are two type of Direct Trouble Codes (DTC) that set and illuminate the Malfunction Indicator Lamp(MIL) or "check engine" or "engine management" light. They are defined as a type A and type B DTC. Type B DTC's are the garden variety DTC's that happen all of the time and not vitally important to the longevity of your vehicle. When the MIL flashes, this is a different type of animal altogether, it is a type A DTC and is defined as a catalyst damaging event, i.e. if it is not dealt with immediately serious internal damage may happen to your vehicles engine and serious damage will occur to your vehicle's catalytic converters. A blown head gasket will cause the MIL to flash. Personally, I had a MIL flashing in my supercharged Mustang GT when I lost fuel pressure under boost and went lean and blow a hole throw my number 4 piston. So as you can see, a flashing MIL is pretty serious to the health of your vehicle and needs to dealt with immediately. Can you please pull the DTC for us and let us know what it is.
Thanks,
Alex
2CarPros
Sep 18, 2019 at 2:37 AM
