Hello, my car is misfiring when warm on cylinder two. I can drive for about ten to twenty minutes and it'll be fine. Once it's misfired, if I restart the car it will run properly for about one minute and then start to misfire again.
I have changed the spark plugs, spark plug leads and coil pack and nothing has changed and I also cleaned out the air filter. There appears to be some sort of grease when I take out the spark plugs after a couple of days so I think the engine may be running rich but this could be caused due to the misfiring.
Any idea of what to do/look for?
Thanks in advance.
Thanks in advance.
Jun 18, 2019 at 8:38 PM
