codes p0303, p0305, and p016, the engine misfire after warming up?
2008 HYUNDAI SANTA FE
131,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
TR917
It runs fine cold but after warming up sends codes p0303, p0305, and sometimes p016?
Sep 3, 2024 at 8:17 AM
Can you please recheck the p016 code, there should be another digit. The codes P0303 and P0305 indicate misfires in cylinders 3 and 5, respectively. So, I would start with a typical tune up and replace the spark plugs and ignition coils which are normal service items.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
NGK Iridium IX: ILFR5B11 (stock number 6596)
Denso Iridium TT: IT20TT
Also, I would service the throttle body as well. Here is a guide to help with that as well:
Once the job is complete clear the codes and take it for a drive to see what happens, here are instructions in the images below for your car. Check out the images (below). Please let us know what happens.
Sep 3, 2024 at 9:42 AM
TR917
Thanks, I already replaced the plugs and coils. the p0016 code hasn't come up after I replaced the camshaft position sensor and the crankshaft position sensor.
Sep 3, 2024 at 11:17 AM
Okay, then misfires like this can be caused by a vacuum leak, dirty throttle body or a bad MAF sensor. Here is a guide to help us and the location of the MAF sensor so you can change it out. If the MAF sensor is bad it may not have a trouble code because when it is dirty it will cause the PCM to lean the fuel system out which can cause the misfire.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Also, check for obvious vacuum leaks, this guide can help:
It might be a good idea to do a compression test, how does the engine sound when cranking? If you upload a short video of the engine cranking, I can tell if you have a problem or not.
Sep 3, 2024 at 2:52 PM
