Hey. I have the car listed above SE model (approximately 117,000 miles on clock) which has engine management light on. Scan showing misfire on cylinder 3 (low compression) and traction control light flashing on the dash. Spark plugs and coil pack have both been replaced. Made no difference in doing so. Recent gasket cover seals kit replaced also. Any ideas? Could any of this be linked to wheel speed sensor? How about the cylinder? Cylinders have been swapped over to determine if spark plug issue. Fault stayed with cylinder 3.
Kind regards,
June
Kind regards,
June
May 1, 2023 at 6:25 PM
