Engine management mode?
2014 AUDI Q7
98,000 MILES • 2WD • AUTOMATIC
DAVID MINIHAN
If I go over 2,500 RPMs engine goes into management mode, when I switch off engine and restart it clears.
Jul 2, 2025 at 1:52 AM
STEVE W.
  • 15,113 POSTS
There are many things that can cause this. The first step would be to use a scan tool to see what is stored in reference to it going into limp mode. You will want a higher-level tool than a basic code reader to see which modules are storing errors and data.
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Once you have that information you can determine what steps are needed to repair it.
Jul 2, 2025 at 6:55 AM
