Engine stalled in reverse, will not start and "engine malfunction" came up
2014 FORD FOCUS
94,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MATTY2101
i used my car to make a 450 mile round trip without any problems. i went to use the car next day and it just stalled in reverse and i got an engine malfunction display. The car will only crank over a few times then stops. I checked for codes with an obd2 scanner, no codes found, then i found 4 DTC codes on test mode.
DTC 1- C415-64
DTC 2- C422-64
DTC 3 1607-82
DTC 4 C100-00
May 5, 2020 at 9:13 AM
Good morning,
The first thing I would do is check the battery since it barely cranks over.
Do you have a voltmeter to do some checks?
Okay, as far as the codes, the should be in this format, the letter C and then 4 numbers.
Where did you get these codes?
May 7, 2020 at 7:10 AM
