Engine losing power
1999 DODGE RAM
116,000 MILES • 8.0L • V10 • 4WD • AUTOMATIC
JOETRACYJOETRACY
  • 25 POSTS
Loss of power.
2500 model, V10 engine. Runs like a new one but lately while driving let's say at 55 mph, it will shut completely down just as if you turned the ignition key off. After coasting to the side of the road I turn the switch key off then back on and it starts right up. I'm able to take off. Most times I can make it like ten miles before it repeats but today it shut off four times like above but always restarted and I'm home now. Was thinking cam sensor. Please I'm poor and can't afford to throw parts at it. Can you help?
Jun 1, 2019 at 11:28 AM
Welcome to 2CarPros.
First, if the check engine light stays on when the engine is running, you need to scan the computer for diagnostic trouble codes. If it is on, there will be helpful information to diagnose the issue.
Here is a quick video that shows how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a parts store will do it for you. Also, they even may lend or rent one.
Now, based on your description, my first suspect is the crankshaft position sensor (not the camshaft sensor). When they start going bad, they can fail like this. Take a look through these links. The first explains the crankshaft sensor's function. The second explains symptoms. The third explains in general how one is replaced.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
__________________________
Now, if the check engine light never stayed on, it could still be this sensor. How I determine if it is bad is by using a live data scanner to see if the RPM signal stops when the engine stalls. If it does, this is my first suspect.
If you look at picture 1, it shows the location of the sensor. I circled it for you. If you determine this is the problem, here are the directions for replacement. The remaining pictures correlate with the directions.
Crankshaft Position Sensor Location
pic 2
The crankshaft position sensor is located on the right- lower side of the cylinder block, forward of the right engine mount, just above the oil pan rail.
REMOVAL
1. Raise and support vehicle.
2. Disconnect sensor pigtail harness from main engine wiring harness.
Sensor Removal/Installation
pic 3
3. Remove sensor mounting bolt.
4. Cut plastic tie strap securing sensor pigtail harness to side of engine block.
5. Carefully pry sensor from cylinder block in a rocking action with two small screwdrivers.
6. Remove sensor from vehicle.
Sensor O-ring
pic 4
7. Check condition of sensor O-ring.
INSTALLATION
1. Apply a small amount of engine Oil to sensor O-ring.
2. Install sensor into cylinder block with a slight rocking action. Do not twist sensor into position as damage to O-ring may result.
CAUTION: Before tightening sensor mounting bolt, be sure sensor is completely flush to cylinder block . If sensor is not flush, damage to sensor mounting tang may result.
3. Install mounting bolt and tighten to 8 Nm (70 in. lbs.) torque.
4. Connect sensor pigtail harness to main engine wiring harness
5. Install new plastic tie strap to secure sensor pigtail harness to side of engine block. Thread tie strap through casting hole on cylinder block.
___________________________________________
Dec 15, 2020 at 12:26 PM
ANDRA3202
Give the truck gas it goes up to about 2100 rpms keep giving it gas to the floor it bogs down. In park or driving
Dec 15, 2020 at 2:49 PM (Merged)
Has the check engine light come on? Have you checked fuel pump pressure?
Here is a how to for checing fuel pump pressure/
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
TJRAMS
Just had my motor replaced on my truck and when you turn the key to crank it it takes about 10 seconds to get it running also once you get it started it feels like the break is on now I had a k&n intake put on and also had flow master duel pipes put on so I don't know what it could be.
I would have the fuel pressure checked. you can rent a tester at a parts store. it may be taking too much time to build up fuel pressure
TJRAMS
Thank you and I'm supposed to take it back to the shop this am and I will have them check, I am unable to do this stuff as I lost my arm recently
sorry to hear that. it sounds like it has nothing to do with the motor exchange but let them check it and keep me updated.
TJRAMS
I will and thanks again. Happy holidays
thanks, same to you and yours
TDGODSIZE
My truck is a 1999 Dodge Ram 1500 short bed with the V6 and manual trans. The truck idles rough a lot, but I don't think it does all of the time, but sometimes it will idle rough and die. It has bad fuel economy as well.I bought the vehicle used and it has never ran quite right. The previous owner said that the engine had been rebuilt or replaced and only had 30 - 40,000 miles or so on it, though he gave me no receipts, but his friend told me it was true. That would put it at around 60 - 80,000 miles now. The vehicle will intermittently lose power and backfire out of the throttle body. It seems to really only happen when it’s cold. It smells pretty gassy upon start sometimes. When it starts to lose power I'll push in the clutch and rev the motor and it revs up no problem and kind of clears out the system and I'll keep the rpms up a bit and ease back into gear and it goes fine. It seems like it runs ok, when it warms up but it might still do it sometimes when its warm. I've put a scanner on it and it showed no codes at all. It also has an aftermarket small air filter on it because the previous owner accidentally ran over the stock unit. The backfiring has started a while after I bought it so I don't think the air filter is the problem, though the filter may be dirty at this point. I've searched this problem on the net and people are saying all kinds of things from the upstream O2 sensor to intake manifold gasket. It's driving me crazy, please help because I don't have the money to just start replacing every possible thing. Thanks in advance.
Without an engine code, it does become a guessing game. Based on the fact that you smell fuel when it happens makes me think it is fuel related. Have you checked the fuel pump pressure and more importantly, the fuel pressure regulator?
Let me know if you need directions or if you have already done it.
TDGODSIZE
Well I don't think I necessarily smell gas when the power loss and backfire happen, just sometimes when I start it it smells gassy. Some days it seems to run ok. I haven't checked the pump pressure or pressure regulator, I don't know how to do that. Any help would be appreciated.
Here is a how to for checking both. Let me know what you find. You will need a gauge, but most parts stores will lend or rent them to you.
STOJAMR
After getting my A/C repaired and hauling about 4000lbs in a trailer, I noticed a severe loss of power in my engine. Felt like it starting in higher gears. This was confirmed by transmission shop who replaced governor and solenoid, and later the torque converter. Happened again a few months later and same things replaced. Check Engine light comes on later and indicates bad cat. It gets replaced. Doesn't run much better, so get tune up which doesn't work. In fact mpg dropped from 18 on hwy to 12. Took it back to shop to find bad intake gasket, get intake replaced. Drives a little better, but still has the same issue. Transmission shop says transmission is good, but says they measure backpressure of 6-12psi. Take it to the cat place and they measure 0 and say it's good. The cat was installed with the arrows pointing against the flow? Could this be the problem? Can a cat be installed either direction?
It should follow the flow recommended. Disconnect it and see if it changes the power. It will be loud, but won't hurt anything. Remember, if the manufacturer took the time to have their castings have arrows showing what direction the air should flow, they did it for a reason.
STOJAMR
I finally got the truck to the muffler place. They removed converter and put in straght pipe and it runs the same. Mechanic says it smells like rich on fuel, but runs like it's starving for fuel? Could it be a fuel injuector problem? Or could a vaccuum leak in engine cause gauge to measure some back pressure. Reading was about 4psi earlier with cat on. Mechanic says muffler is good.
I would start with checking for vacuum leaks. After that, check fuel pump pressure. Here is a how to:
