ENGINE LIGHT WARNING...
2014 FORD FUSION
48,069 MILES • AWD • AUTOMATIC
TAHESIAFORD
Engine light comes on and sensor says engine coolant over temperature. The sensor was changed thinking that it was a defect but that wasn't it. There's no signs of car running hot the temperature gauge needle stays in the middle and doesn't move towards hot. Also, when I crank it, I can hear a loud "pouring water" sound that's coming from under the hood, behind the steering wheel.
Dec 19, 2015 at 3:48 AM
HMAC300
  • 48,601 POSTS
the water sound may be the heater check battery terminals for being clean then check ground from battery to engine.
Dec 19, 2015 at 6:53 AM
TAHESIAFORD
Ok. Thank you. I'll get someone to check that.
Dec 19, 2015 at 7:42 AM
