tHE CAR RUNS GREAT THE COMPUTER CODE IS PO717 TURBINE/INPUT SHAFT SPEED SENSOR "a" CIRCUIT NO SIGNAL.
I was told this sensor is located above the trans and the lights are all lighting because it needs to be changed, is this true? the runs like new trans feels great .. I just dont want to sink money into it if this sensor is not the whole issue. Mechanic says once the sensor is replaced the all the warning lights will go away.
I just bought it $3000.00 I dont mind putting some money into it I knew buying a car used I would have to.
MArk
MArk
Mar 11, 2014 at 9:58 AM
