Engine light on with error code: P2185 ECT sensor 2 circuit high voltage
2006 HONDA CIVIC
90,000 MILES • 1.4L • AUTOMATIC
SHAJEE
Car: SE I-DSI S-A five door hatchback.
I get intermittent engine light coming on/off and when took to a local garage and the diagnostic meter showed the below error code:
P2185 ECT sensor 2 circuit high voltage.
The above error I believe is due to the ECT sensor but I am confused which one it is the one near the radiator or the other one.
I do not want to pay honda just to diagnose and tell me the sensor as it costs too much for their diagnostic and in the same or less amount I may manage to buy the right sensor and get it fixed.
Your help will be much appreciated.
Regards,
Shajee
Nov 24, 2014 at 3:36 AM
HMAC300
  • 48,601 POSTS
The sensor they are talking about with that code is the engine coolant temperature sensor on the engine.
Here is a guide to help you see what you are in for when changing the sensor out and the location of the sensor on your car below.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Cheers
Nov 24, 2014 at 6:38 AM
