If the check engine light was flashing, that normally indicates a misfire. By any chance, do you know the codes that AutoZone found?
As far as fuel pressure, if it is too high or too low, it can cause a misfire, but I don't believe there is a code just for the fuel pump. Usually, you will find a lean or rich fuel mixture code.
If you want, here is a link that explains how to test fuel pressure. You can try it to see if there is a problem.
Here are the manufacturer's specifications:
2017 Dodge or Ram Truck RAM 1500 Truck 4WD V6-3.6L
Fuel Delivery System - Pressure Specifications
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Specifications Pressure, Vacuum and Temperature Fuel Delivery System - Pressure Specifications
FUEL DELIVERY SYSTEM - PRESSURE SPECIFICATIONS
FUEL SYSTEM PRESSURE-GAS
58 psi +/- 2 psi
If possible, let me know what codes were found. If you have other questions, let me know.
Take care and God Bless,
Feb 23, 2021 at 7:59 PM
