Engine light on and truck is shaking
2017 RAM 1500
44,079 MILES • 3.6L • V6 • 4WD • AUTOMATIC
FEODINERO1
My engine light came on and shortly after I noticed my vehicle started to shake when in park. The engine light started blinking and I noticed the shaking worsening. I did a diagnostic at AutoZone and it said it was my fuel pump but I’m not sure if that’s the issue.
Feb 23, 2021 at 2:37 PM
If the check engine light was flashing, that normally indicates a misfire. By any chance, do you know the codes that AutoZone found?
As far as fuel pressure, if it is too high or too low, it can cause a misfire, but I don't believe there is a code just for the fuel pump. Usually, you will find a lean or rich fuel mixture code.
If you want, here is a link that explains how to test fuel pressure. You can try it to see if there is a problem.
Here are the manufacturer's specifications:
2017 Dodge or Ram Truck RAM 1500 Truck 4WD V6-3.6L
Fuel Delivery System - Pressure Specifications
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Specifications Pressure, Vacuum and Temperature Fuel Delivery System - Pressure Specifications
FUEL DELIVERY SYSTEM - PRESSURE SPECIFICATIONS
FUEL SYSTEM PRESSURE-GAS
58 psi +/- 2 psi
If possible, let me know what codes were found. If you have other questions, let me know.
Take care and God Bless,
Feb 23, 2021 at 7:59 PM
FEODINERO1
The code found reads P0300. Only other thing I noticed is the engine temperature gauge remains down on the C for quite some time. I’m not sure if that’s normal or not.
Feb 24, 2021 at 7:23 AM
Okay, the P0300 indicates a random cylinder misfire. As far as the temperature gauge, that could be part of the issue. If the ECT (eng coolant temperature sensor) is faulty, it could be causing an issue with the air/fuel mixture sent to the engine.
If your scan tool can provide live data, see what the ECT indicates. If the engine is cold, the temperature should be close to the outside ambient temperature.
Do that and let me know what it says.
Feb 24, 2021 at 5:28 PM
