Check engine light code P0340
1997 LAND ROVER DISCOVERY
150,697 MILES • 4.0L • V8 • 4WD • AUTOMATIC
TIMOTHY BOOKER
I have a problem with code P0340. What do I do?
Feb 7, 2018 at 10:46 PM
KHLOW2008
  • 41,814 POSTS
P02340 is a fault with the cam angle sensor circuit. First thing to do is to check the sensor wires for proper connections and no fault with the wiring or connectors. Next is to test and confirm if the sensor is good. You would need to check the cam sensor pickup point for damage.
Try these first.
Feb 8, 2018 at 2:44 AM
