I am pretty certain that the valve lash is too much on my XB engine. I know it has lifter buckets and I was wanting the procedures to check the valve lifter to cam clearances and then remove the lifters to replace with appropriately sized ones. I believe there are size choices on the lifters and the part numbers are different when ordering from dealer. I know the cams must be removed and timing chain just moved to the side. I read that the underneath of the lifter buckets tends to wear out more than the valve stem itself so the proper lifter replacement should alleviate my problem with the clacking noise. Please help, and first i should check clearances. Furthermore, I plan to change the serpentine belt during this time, FYI.
Jan 14, 2022 at 8:17 PM
