You can do the test yourself but if you never did this. it would be better to have a shop perform it.
You need to remove the oil pressure sensor and install the manual gauge.
Engine Oil Pressure (EOP) Switch
Material
Item Specification
Motorcraft® Thread Sealant with PTFE
TA-24-B WSK-M2G350-A2
Removal
4x2 vehicles
With the vehicle in NEUTRAL, position it on a hoist. Refer to Section 100-02 .
4x4 vehicles
Remove the generator. Refer to Section 414-00 .
All vehicles
Disconnect the EOP switch electrical connector.
Remove the EOP switch.
Installation
All vehicles
NOTE: If the oil pressure switch is to be reused, apply thread sealant.
Install the EOP switch.
Tighten in 2 stages.
Stage 1: Tighten to 14 Nm (124 lb-in).
Stage 2: Tighten an additional 180 degrees.
Connect the EOP switch electrical connector.
4x4 vehicles
Install the generator. Refer to Section 414-00 .
Jan 12, 2021 at 2:32 PM
