I need 3 to 20 times to fire it up, until it runs. If it runs, it is stumbling and often dies with a little backfire in the intake, so I've to restart it. When the car is running for a few minutes and the engine gets warmer, the stumbling is gone and it drives more or less, without any problems, but it seem to have low acceleration.
The car is very well maintained. I replaced any sensor around the engine and intake system, tested and changed the injectors, put new timing chain with gears and camshaft position sensor and magnet on it. All intake gaskets are new. No oil or cooling fluid gets burned. Sparks looks like there is a lean mixture problem (light grey powdered). Fuel pressure seems to be good, because if I push down the little valve at the fuel rail, the fuel sprays out to the open hood.
There are new spark plug wires and a new coil pack installed and also a new ICU. The ECM is also new.
The computer shows me a faulty cam sensor, but it got replaced 7 times (I tried the parts of all aftermarket manufacturers), but noting worked to get the that faulty code finally deleted. It always comes back during starting procedure.
I've also checked the wiring from cam and crank position sensor to ICU and ICU to ECM, but all looks good.
If you have any further ideas to eliminate the starting issue of my car, or to get permanently rid of the faulty code, I would appreciate your help.
Feel free to ask, if you need more details.
Many thanks
Many thanks
Aug 16, 2020 at 5:39 AM
