Hi I have been using the guidelines set up in the engine performance section for common issues with engine stalling. I've checked the following troubleshoot tasks. Cleaned and checked vacuum hoses to throttle body and EGR valves for vacuum leaks. disconnected and reconnected for power failure and any source of malfunction one sensor at a time. MAF. TPS. I A intake valve and Oxygen sensor . Checked and cleaned air filter. boot cracks, Cleaned all battery connections positive/negative and ground, No blown fuses or loose relay circuits. Replaced the Crankshaft sensor, throttle body gasket and TPS sensor. Idle Air intake valve and fuel filter was replaced about a year ago and my next move is the fuel pump but before I replace it how do you know if the EGR valve is stuck open ? The only symptom is when giving gas to engine either gas pedal or throttle cable then it stalls. I can't drive it at all.
Aug 15, 2015 at 12:42 AM
