Since the weather has gotten colder, I've had this weird issue. If I'm parked on a hill with the nose facing downward and crank the cold engine, it will start out idling fine, then after a minute or so it will start idling really low and the whole van shakes, then the engine dies. I can turn around and crank it back up and it will run fine - but there is no CEL indicating a problem.
It has happened twice so far this winter. The second time the engine didn't totally shut off, but it almost did before it revved back up again and the battery light flashed for a split second.
I tested the battery with a load tester and it's fine (it's only 2 years old). Alternator was also replaced maybe 3 years ago. Could it be fuel pump/filter? Without CEL/error codes it's hard to tell...
Jan 20, 2026 at 8:47 AM
