After replacing the MAF, MAP, TPS, EGR, pump and filter, addressing a possible grounding issue for fuel pump, which I knew some of these items were bad, very old and going bad, or not thoroughly reliable during vehicle use. I began testing things with a little confidence that I was going in the right direction. (Still no CEL, and scanner shows MAF problem) The vehicle still had a part throttle stumble like there was a fuel delivery issue. However, the vehicle had tire chirping torque that was never there before. As we know this is very bad, and must be corrected. Obviously fuel trim is wacky. Also had unusual power supply at MAF. Replaced ECM with a re-flashed item matched to my VIN. This helped immensely, but the stumble was very slight and barely evident. After driving vehicle about forty miles, vehicle does not stumble and fuel trim seems correct. I suspect there was a fuel pressure regulator problem that corrected itself, or the ECM finalized some adjustments. The vehicle runs very well now.
Sep 2, 2018 at 6:13 AM
