Engine hesitation
1997 CHEVROLET BLAZER
174,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
LOCKDUDE
Just prior to second gear shift engine acts as though it is starved for fuel. All other aspects of operation are normal. New pump, TPS, fuel filter, cleaned pump wiring ground on frame, new air filter, recent plugs, wires, cap and rotor.
Aug 2, 2018 at 7:54 PM
It sounds like the MAF sensor is not working right do you have any codes? Here is a guide to help us get started:
Please let us know what you find.
Aug 4, 2018 at 3:23 PM
LOCKDUDE
I checked the MAF and it checked good. Hz findings were what seemed appropriate. So that leaves the MAP sensor, which was also original. Test results looked a little shy on the meter. So I changed it with no improvement. However, it was 21 years old. Scan tool showed intermittent misfire. Unplugged the MAF, and bingo, the problem was gone. One mechanic on the net had stated the MAFs will sometimes test fine, and still be bad. This seems to be the occurrence in my case. New MAF sensor is on order. There also was never a MIL lamp until I unplugged the MAF and drove the vehicle. Plugged in the MAF, and hesitation returned, MIL lamp went out. Thanks for all your suggestions. Hope my info helps you and others. Keep up the good work!
Aug 5, 2018 at 8:00 PM
It does help. Here is a guide to help people see whats its like to replace the MAF sensor:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Aug 6, 2018 at 9:36 AM
LOCKDUDE
After replacing the MAF, MAP, TPS, EGR, pump and filter, addressing a possible grounding issue for fuel pump, which I knew some of these items were bad, very old and going bad, or not thoroughly reliable during vehicle use. I began testing things with a little confidence that I was going in the right direction. (Still no CEL, and scanner shows MAF problem) The vehicle still had a part throttle stumble like there was a fuel delivery issue. However, the vehicle had tire chirping torque that was never there before. As we know this is very bad, and must be corrected. Obviously fuel trim is wacky. Also had unusual power supply at MAF. Replaced ECM with a re-flashed item matched to my VIN. This helped immensely, but the stumble was very slight and barely evident. After driving vehicle about forty miles, vehicle does not stumble and fuel trim seems correct. I suspect there was a fuel pressure regulator problem that corrected itself, or the ECM finalized some adjustments. The vehicle runs very well now.
Sep 2, 2018 at 6:13 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Sep 3, 2018 at 12:48 PM
