Hello, this is my problem. so my coolant leaks and i maintain to fill it regularly. but one day i forgot the the coolant cover open and drove for about two hours without speeding. no heating problems. next day i saw the coolant. i have fill it again and closed it. car start heating. apparently it still has air inside the coolant even tho i have filled it with water. the start to over heat so fast. i have stopped and waited for it to cool. and drove home. ( not far from where it heated 250 meters). any way i have taken out all of the air in the coolant refilled it and drove again. and this time no heat what so ever. Everything is fine. then i hear clicking noise either in the engine or the fan. the car stops i managed to get working again but every time i push the gas pedal the noise become even louder and the car stop again and by stop i mean the engine is dead. i called a tow truck took it to a mechanic.
here is the important part.
the mechanic says nothing major is damaged all you need is to change the radiator and the thermostat tube the front one.
is that correct ? by correct i mean seems reasonable ?
and do i need to change also the back thermostat tube ?
Thank you all.
Thank you all.
May 23, 2019 at 6:08 PM
