Thanks for the update. Normally I get pretty close to the issue but I didn't expect that one. Normally the battery will keep it running until it can't sustain it any longer and then it won't restart so its odd that it started but shut off. I suspect the PCM was getting the low voltage and it was shutting it down but it had enough to run the starter.
Thanks for the info. I am sure that info will help others that have similar issues. Thanks
Oct 5, 2019 at 7:07 PM
