Engine goes into reduced power mode with P2101 and P1516 codes. After clearing codes, the engine will start, and I can press the gas pedal to increase RMPs a bit. But after a bit it will go into reduced power. The pedal will do absolutely nothing at that point. No increase in RPMs at all. It will only idle. I replaced the throttle body with a scrap yard throttle body, same symptoms. I put back in the original throttle body. Same symptoms. Any suggestions or questions or something to try?
Feb 15, 2025 at 8:44 AM
