I have the vehicle listed above with a 2.5l and 6 speed manual, will an engine from an aid automatic fit?
May 20, 2023 at 9:04 AM
CERTIFIED EXPERT
If the engine is from the same year, make, and model, it should work. I believe the only automatic transmission used was an FW6A-EL. What are you referring to when you say AID?
The transmission bell housings should be the same, auto or manual, so it shouldn't be an issue.
May 20, 2023 at 10:22 PM
BHAMDOC1973
MEMBER
Sorry meant to say AWD.
May 21, 2023 at 5:08 AM
CERTIFIED EXPERT
No problem whatsoever. I was concerned that you had something I never heard of. LOL
Regardless, if you have a chance, let me know how things turn out for you.
