No problem. The diagnostics are to determine if the pick-up/crank sensor is working properly.
If you are uncomfortable performing the test, by any chance do you have access to a different distributor?
If not, try this. Disconnect the battery for approximately 30 minutes. When you reconnect it, the code should be cleared. At that point, crank the engine a few times and see if the code comes right back. If it does, I suspect the distributor may need replaced.
Apr 28, 2024 at 7:03 PM
