Engine air filter?
2023 KIA FORTE
6,000 MILES
ALYLAROSA485
  • 142 POSTS
Had previous rodent issues but haven’t had any activity in a while. Routinely check engine bay and filters just wondering if this filter looks good?
May 5, 2025 at 6:15 PM
Yep, that air filter looks good. I would run it :) You might want to clean out the air filter box before reinstalling the filter.
May 6, 2025 at 11:52 AM
ALYLAROSA485
  • 142 POSTS
I checked under the filter and the box was completely clean. I noticed black on the pleats is that just dirt? You can see it in the picture along the pleats of the filter folds.
May 7, 2025 at 8:47 AM
Yes, there is a little dirt on it but not enough to warrant replacement.
May 8, 2025 at 10:43 AM
ALYLAROSA485
  • 142 POSTS
Checked engine filter and on intake side it was a little grey and soiled thinking of replacing . Is carquest a reputable brand? Also does this look dirty enough or should I wait ?Currently have kia oem filter
May 8, 2025 at 11:16 AM (Merged)
You can do either, replace it if you want or replace it. I would use name brands like, Denso.
May 8, 2025 at 11:18 AM
ALYLAROSA485
  • 142 POSTS
So then is it dirty enough to replace or hold off? I also noticed some leaves and dead bugs in the air box that I cleaned out.
May 8, 2025 at 1:34 PM
I would replace it for peace of mind. Make sure to add it to your maintenance schedule.
May 9, 2025 at 8:58 AM
ALYLAROSA485
  • 142 POSTS
Okay how long do they last?
May 9, 2025 at 9:01 AM
It depends on how dirty the roads are that you drive on, but I would check it every time you change the engine oil.
May 9, 2025 at 9:26 AM
ALYLAROSA485
  • 142 POSTS
The roads aren’t too bad, just a lot of pollen but my grandma's car only has 5,000 miles after 2 years, so she doesn’t need many oil changes, I think she still has another 3,000 miles before the next one. Do oil changes for synthetic need to be done every 6months? That’s what the dealership said but that seemed excessive.
May 9, 2025 at 12:41 PM
It is mostly mileage for the oil change which should be between 6 and 7k. Have a nice weekend.
May 10, 2025 at 11:34 AM
