The engine will idle fine, when placed into drive it will drive for about a block and then it will start sounding bad almost like its knocking lightly. Then the rpm will drop to low at a stop and it will shut off. Starts smelling hot but temperatures show normal. Light smoking but I think that is just excess oil. The car was just serviced at the Ford dealership and had a tuneup and oil change. Where should I begin the diagnosis and what types of problems may be causing this issue?
Thanks ahead of time.
Apr 3, 2017 at 8:44 PM
