Engine failure
2008 DODGE AVENGER
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
HUKABUK75
The engine idles rough on start and doesn't have a lot of power and wants to shut off when stopping it will restart but barely wants to move today the throttle sensor came on just barely got off highway to safe spot
Jun 3, 2018 at 3:07 PM
Hi and thanks for using 2CarPros.com. First, there are many different things which can cause what you described. Since the vehicle is running this poorly, I assume the check engine light is on. What I need you to do is scan the computer and let me know what codes are stored in the computer.
Here is a video for scanning a computer:
https://youtu.be/YV3TRZwer8k
Here is a link that discusses possible reasons for low power:
https://www.2carpros.com/articles/engine-has-low-power-output
Once you determine what trouble codes are stored in the computer, let me know. That way, I can better help you determine the cause of the issue. Otherwise, there are too many places to start.
Let me know what you find.
Jun 3, 2018 at 5:41 PM
