engine stalls after seconds from ignition
2012 TOYOTA CAMRY HYBRID
60,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
BEBOBEBO
  • 116 POSTS
I did an overhaul for my engine then after that the mechanic started the car, but after less than five seconds the car shut down and stopped.
obd11 diagnosis showed these codes
1- p0011 camshaft positin.
2-p0328 knock sensor system.
3- p3190 poor engine power.
Please what is going on and what to do?
The mechanic is confused and does not have thoughts except that he told me it could be ECU or the computer of car is not working.
Please help!
Jul 21, 2016 at 7:06 AM
HMAC300
  • 48,601 POSTS
it could be many things including the codes, but try resetting security system if no manual look online for your car. then erase codes after you get it running and then drive it and re-scan it.
Jul 21, 2016 at 9:48 AM
BEBOBEBO
  • 116 POSTS
I want ask once I start it it cranks and start then after less than three seconds it stopped
do you have an idea what are the causes that could do like this habit?
Jul 21, 2016 at 1:01 PM
I would check all of the system grounds, it sounds like he forgot to hook one of them up.
Let me know what you find,
Best, Ken
Jul 21, 2016 at 1:44 PM
