I had a buddy of mine run a test through on my car and it was throwing up p0300 p0463 and p0128. I was wondering since you've worked in GM so long and seem to be pretty knowledgeable what you think the problem most likely is causing all those codes. My car to roughly idle really bad and barely make it point to miles down the street one week then 2 weeks later it makes it all the way like a 20 minute drive and 20 minutes back without a hiccup with a slight misfire terrible fuel mileage as well used to get like 26 miles to the gallon. now I'm only getting like not even 17, but no smell of fuel, no leaking from anywhere in or around the engine. I could really use your advice guys. thanks.
Mar 20, 2022 at 6:52 AM
