So, here's a theory: after going through pages of service info and coming across some Technical Service Bulletins (TSB) about either Output and Input speed sensors on the transmission malfunctioning or pin contact inside the connectors. Or the Transmission Control Module (TCM) connector pin issues. Diagrams 1-3 are for the Transmission Output and Input speed sensors, diagrams 4,5 show the relationship of the speed sensors and the power feed diagrams. In the 3rd diagram you can see that it also feeds power to the Blower Motor relay.
Diagrams 6,7 are the TCM connector C933 where the Transmission Range Switch, 8 is the TCM speed sensor connector C93-2.
According to the TSB malfunctions in these areas can trigger faults when shifting from Park to Reverse or Park to Drive. So having the transmission control module and engine computer for any diagnostic trouble codes may show something.
The 9th diagram shows a location where there might be a wire pinched under a bolt or hold down screw. These locations shown should be on the passenger side down where the foot area is. In the 1st picture you can see the side of the blower motor.
The connectors in the 7,8 diagrams are on the Transmission Control Module which is located behind the lower center of the dash (diagram 10).
There is a huge list of TSBs for this transmission, so the manufacturer is aware there are a lot of problems with them. But I would start with having the vehicle scanned for any diagnostic codes, a full vehicle scan. If there are no codes stored at all, which there should be with the stalling out. But if there are none, then inspecting the connectors and wiring would be next.
Apr 30, 2023 at 9:51 PM
