Engine Drops 50 RPMs at idle?
2016 HYUNDAI TUCSON
106,800 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
  • 12 POSTS
Engine replaced at 87533 miles (long block). At 106,812 miles the engine started to stumble at idle dropping about 50 rpm intermittently. Sometimes it won't do it for 10-15 minutes. Once in a while it will also surge up to 1100rpm and immediately drops back down. There is no check engine light. Using AI I methodically replaced the following parts.
plugs
coils
battery
high pressure fuel pump
throttle body (imbedded TPS/MAF)
Acceleration Position Sensor
temp sensor
fuel rail
fuel injectors
air filter
PCV
I disconnected O2 sensor (primary and secondar) one at a time and the engine check light came on immediately in both instances. I assume they are working.
I used an OBD II tester to check live settings (I do not know all of what they mean. but was checking for catalytic temperature since AI suggested that if the temp was too high it might indicate a blockage [temp was 890 and Hyundai specs say between 800-1100 is normal]).
Dealer couldn't find a problem/source and said since some of the parts I used were not Hyundai OEM (E3 plugs) they wouldn't go any further with diagnostics. What rot.
Jun 14, 2025 at 3:27 PM
Yep, the dealer will bow out without OEM parts. But I can tell you I have seen the fuel pressure control valve cause this issue, but you said you replaced it, correct? Also, if you have a vacuum leak, it will do this as well, ie: lose intake manifold, broken vacuum hose. Please go over this video to help you find it, the machine costs about $65.00 on Amazon.
https://amzn.to/408Y25d
Can you tell me what the short- and long-term trim is on the scanner? Here is a guide that can help as well:
https://www.2carpros.com/articles/low-engine-idle
Jun 15, 2025 at 11:10 AM
  • 12 POSTS
Thanks for your reply. I did not replace the fuel pressure control valve. I will get one and see what happens. Thanks I will post again to let you know.
Jun 18, 2025 at 1:06 PM
Did the high pressure fuel pump come with the valve? All of the pictures I have seen have the valve on it?
Jun 19, 2025 at 9:34 AM
  • 12 POSTS
Looking at OEM part for a picture of the valve, I realized that it did not, and I ended up using the original one. I should get the valve this coming Thursday and will let you know if it is a cure. Thanks again...
Jun 21, 2025 at 6:37 AM
Sounds good have a great Sunday!
Jun 22, 2025 at 12:16 PM
  • 12 POSTS
I got another reader because my old one would not exit. Anyway. Here are the pics off the new reader
Jul 6, 2025 at 2:15 PM
It still sounds like you have a vacuum leak, did you get the smoke machine and try it? If you can get the long and short trim values I can tell you if the engine is lean or not. It seems like it can be the intake manifold gasket is leaking. Please let me know.
Jul 7, 2025 at 10:05 AM
  • 12 POSTS
Replaced the fuel pressure control valve - no change. Will get the smoke machine. My friend has a better reader. Going there on 7-14 and will upload pic of reader findings.
Jul 12, 2025 at 5:46 AM
Sounds good, we are getting closer.
Jul 12, 2025 at 9:49 AM
  • 12 POSTS
Local shop pressure tested fuel and smoke tested vacuum. Both good. Ended up replacing the fuel rail pressure sensor recommended by AI bot. It worked perfectly until the next morning when I started out and within two minutes it went right back to cutting out, but no worse.It really bugs me with less than 25k on the engine. ECU?
Aug 4, 2025 at 12:36 PM
Can you get the long and short fuel trims so we can see what the computer is doing? It sounds like the MAP sensor is weak, also can you pull the spark plugs to see what color they are? Here is the location of the sensor so you can check it out.
Aug 4, 2025 at 1:53 PM
  • 12 POSTS
Plugs are brown. MAP was replaced with the throttlebody. I will ask him if his reader will do trims and bring to me on Wed. Thanks
Aug 4, 2025 at 5:52 PM
When installing the sensor did the O ring seal get replaced/installed? This is what seals the sensor to the vacuum. Also, be sure there is no exhaust leak as well, this can allow fresh air into the exhaust system and fool the computer which can lower the idle. Please go over this guide as well
Aug 5, 2025 at 8:23 AM
  • 12 POSTS
Yes new o-ring used. No sign of exhaust leakage. Here are pics of the reader. Note the two which show the TRIMs LT ST reflect the ST changes but not the LT.
Aug 6, 2025 at 1:54 PM
I am sorry I cant read any of these they are two small. Can you break them up please?
Aug 7, 2025 at 5:55 PM
  • 12 POSTS
I put four in a row. I hope that helps
Aug 7, 2025 at 6:31 PM
Thanks you, okay it was like I thought, the PCM is thinking the system is lean, here are choices for the cause and a guide as well.
1. Small vacuum leaks (hoses, intake gasket)
2. Slight MAF sensor contamination
3. Weak fuel injector spray pattern
4. Dirty or restricted fuel filter
5. Low fuel pressure from fuel pump beginning to fail
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
I would recheck the vacuum leak, did you use a smoke machine? Please go over this video and get back to us.
https://www.youtube.com/watch?v=LRKWV4Are5c&t=3s&pp=0gcJCa0JAYcqIYzv
I am curious to what you find.
Aug 7, 2025 at 7:00 PM
  • 12 POSTS
MAF is new. Injectors are new. Used carburetor cleaner around every connection I could see without change in idle pattern. Local shop paid to check it but tried an old manual way after your comment. I ordered a new fuel pump assembly which incls the filter. Will change it out when it arrives. If no change I will buy a smoke machine. Will get back to you.
Aug 11, 2025 at 7:47 PM
Okay, it looks like you are on the right track, thanks for getting back to me.
Aug 12, 2025 at 8:35 AM
  • 12 POSTS
I can't believe it, BUT, after going through your logic and having replaced everything under the sun, I decided the only left to do without parting it out for sale was to just replace the E3 plugs and put HEET in the tank because I found a small dollup of water in the fuel pump, was to put exactly OE NGK specific plugs in it. DAMMit the E3 were the exact heat range specified and worked flawlessly for 21k miles yet now it runs perfectly for now for two days... I can only surmise the ECU was trying to compensate for the extra spark the E3s can produce. I am at peace and have a near total refurb engine. Thanks for your skill and informed info.
Aug 21, 2025 at 10:45 AM
Yep, sometimes the problems fight us, but if we stay after it, we will always win, that is what I like about automotive. Please use 2CarPros anytime we are here to help.
Aug 21, 2025 at 6:52 PM
