Hi everyone, I want to know is it necessary to find my engine drain plug to flush out the entire coolant system in my 3VZ-FE engine on my car listed above LE? If so, where is the location to the plug? I read in my service manual said that it’s located on the right side of the engine but I can’t see it. If it’s not necessary do I just use the radiator plug to drain everything?
Thank you.
Thank you.
Dec 13, 2020 at 7:02 AM
