engine does not turn over with key?
2004 FORD BANTAM
256,754 MILES • 1.3L • 4 CYL • FWD • MANUAL
SHAUN LOTTERING
engine does not turn over with key. I opened the ignition relay and pushed the points together. the engine swings but does not start. could it be a faulty relay.
Jan 26, 2015 at 9:22 AM
HMAC300
  • 48,601 POSTS
we don't have that model in U.S. but try resetting security system if no manual look online
Jan 26, 2015 at 9:26 AM
This is the same a as a ford focus, I would check the floor mat to make sure you can push the clutch pedal in completely, please go over this video which will help
https://youtu.be/lXLJbuAZ4CE?si=TG58cVeApCMS9ln_
Here is the starter motor wiring diagrams so you can see how the system works. Check out the images (below). Please let us know what happens.
Sep 9, 2024 at 5:29 PM
